mine turned on itself in the middle of the night too the day I updated. Didn't do it last night.
being a bit laggy every now and then I can live with, but turning on itself for no reason is a pain in the *****.
Well just updating the new firmware on my TV see how it gos if I have any problems this time it's going back
Almost 100% sure it was the Raspberr Pi that turned mine one via CEC. I conected the Pi to the tv's USB, and 5 min after tv is turned off, i guess that turns off the usb and on again, which reboots the Pi, resulting in the Pi turning the tv on again
Haven't checked yet, but it dawned on me during the morning, that this must the scenario
@chbjerg, I can confirm that the usb on these sets do seem to turn themselves on and of whilst in standby, well I can assume they do at least. Our Kdl43w755c No.4 used to power on and off our usb hdd whilst in standby, you would hear the drive spin up. Haven't noticed it yet on tv no.5
It's a satellite tuner, but not a Freesat one.
I don't know who is selling it as 'only Freeview' but it isn't Sony; see here, where the twin satellite tuners are firmly still part of the spec.
If you were sold it as having Freesat, then you were missold. But are you quite sure they said 'Freesat'?
If you were sold it as having satellite and 4OD, then you were likewise missold. At best, at present, it is 'or'.
I have pressed YouView on the topic of why you cannot have satellite and YouView together, but no official reply has been forthcoming. I find it discourteous that they have completely ignored my perfectly reasonable question.
One might hope for co-existence in a future upgrade, or possibly for co-existence on a 2016 model, if the issue is memory footprint, and the 2016 models come with more memory.
The Kremlinology of YouView is generally that they will often tell you things if it's their fault, but not if it is somebody else's. But it may be safer to examine the entrails of a goat for clues, rather than rely on this supposition 🙂
Hi
I ask my question again.
Should the "Auto Picture Mode" work for the "TV" it is greyed out for me, if i choose an input (HDMI) i can then choose, auto, Auto (24fps) or off ?
Many Thanks in advance
Possibly have said all is ok a little early... Just had to do a reset due to sound but no picture. Lip sync is better but not perfect (using the TV speakers - not a sound bar).
My KDL50W807 only arrived yesterday, I did the software update after setting up and so far all has been ok.
no lip sync issues for me but I have all my devices plugged into my AV reciever which feeds the TV.
I did notice that my tv turned itself on twice yesterday when I was stood near it but both times it happened I had just been using the Sony remote app on my iPhone.
Just an update from me. Had an engineer visit yesterday from a local company on behalf of John Lewis. After establishing that I had the latest firmware already, the engineer agreed there is absolutely nothing they can do to resolve these issues as they're definitely software related (as if I didn't know already).
Had a fairly in depth discussion with him and he agreed that Sony's Android TV implementation is not going down well with lots of customer complaints of issues like those being discussed here. He agreed that I'd be better off persuading JL to refund me and getting a Samsung instead so I'm off to JL at lunchtime to begin the saga of convincing them that my Sony is not fit for purpose and therefore I'm entitled to send it back.
FWIW even after the latest firmware I'm still getting sound sync issues - at first it was looking better but last night I was watching a Youtube video and it started off okay but after a few mins the sound was suddenly 4 or 5 seconds behind the video and nothing I tried was able to fix it, aside from a full power cycle. Also had a new issue since the update where the input selection menu (that appears down the left when you switch inputs) would disappear immediately when you pressed the button, meaning you couldn't change input at all. Trying from the home screen didn't work either - as soon as you scrolled down onto the inputs section, it disappeared!
Just fed up with it now.
Sony Rep visited my place to check TV and agreed nothing he could do and gave me option either to take refund or he can send technician for further check. Obviously I disagreed for technician and opted to return it back and bought Samsung. One word for Samsung after using Sony that it's generation ahead of Sony. It's very responsive and everything works as it should. The experience is switching from Chinese phone to iPhone 😜 I'm signing out of this forum, but my suggestion if you can then get rid of this crap and buy which is worth the money.
