For those thinking of replacing the Sony with Samsung, which I have already done, make sure that the replacement Samsung has a Samsung panel and not a Chinese AUO, or Sharp or Chunghwa panel.
Mine has an AUO panel, but there's no way to tell without looking at the service menu in some cases.
The genuine Samsung panel is undeniably better quality than the alternatives, so it's worth checking the AVForums Samsung threads to find out how to check before buying if you want to ensure a genuine Samsung LED panel.
I wish I'd have known this before buyting mine.
This is one area where Sony definitely has the edge - IMHO.
This. Exactly this.
I find that if I pause sky, go away for half an hour and come back. The TV will not respond to the remote and it takes a power off to fix it!
Brand new TV and I love it but this is going to cause problems...
@elraouk wrote:
It's not the remote, as it starts working fine again after 30 seconds and, as I said, I tried another remote to check if it was a remote issue or tv issue.
I've got two of these TVs and when it locks neither remote works (they are pretty new batteries too!).
I've attained a great age; generally in life I've found it's not a good idea to nay-say something until I've tried it.
See my earlier post https://community.sony.co.uk/t5/televisions/2015-bravia-android-tv-issues/td-p/1949079/page/468 post #7
I had exactly your problem , apparently, on reading your post. I don't have two remotes but do have the Sideview app on my phone. I wasn't expecting to have to change batteries either.
Call curry's you've bought a TV that sonys firmware update has bricked. You bought from them they should sort it. Good luck.
same problems here tv is laging had to unplug it 2 times at the wall this is a joke off to curry to find out what my opions are.
SONY YOU ARE A JOKE EVRY PEICE OF SONY TECH I HAVE BOURGHT I HAVE HAD PROBLEMS I SHOULD OF GONE WITH MY GUT INSTINCT BUT THE ANDROID PUSHED ME TO BUY. AFTER ALL THE BROKEN PROMISES THEY MADE WITH THE PS VITA I SHOULD HAVE KNOWN.
Software of 2nd Feb Ver PKG3.179.0100EUA, installed no factory reboot as yet.
Findings.. Set much more responsive soon after switch on. But I have noticed two issues.
1) once it stopped responding to the remote, I waited as I had learned to do with old version, tried the restart by holding stby key down, the set went off to Black Screen, LED off Sound still running. Would not restart automatically. Switched on with remote, sound and picture but LED still off. Could not reset via stby button so went thro settings 'restart option' Seemed to clear the issues.
2) Then today using Kodi app, after many keypresses navigating thro menus. Remote froze and LED did not dim as usual on keypress, tried Sky remote volume settings didn't work either. Waited 30 seconds and remote started responding. Yes I have tried new batteries in the remote.. this is repeatable.
I see others reporting the remote issues in item 2) Sony need to address this. I was promised by the office of the European CEO, that my issues would be resolved with this update.. not all of them have, it's just a bit better. Fix the remote freezing issue AND provide HDD & PAP as promised in March then I will be happy.
@elraouk@ elraouk wrote:
Have also found that remote (normal button one, not touch remote which I don't have) has started off being more responsive and is fine for general light use.
However a number of times it has locked up in kodi or ES when I've been tapping buttons to scroll through long menus / lists. Wait 30 seconds or so and it comes back to life.
During this time tv won't respond to original Sony remote or my one for all (which works when tv not locked up).
I have exactly... this problem - new firmware installed. I'll have to write down all my settings and installed apps. and Kodi add ons, before I do a factory reset. Just to see.
Well, all credit to John Lewis. Went in expecting a fight to exchange my TV given that it was outside their normal 90 day returns policy, but they read the engineers report stating it was a software fault and therefore not something they can fix, and basically said go and pick the one you want to replace it for!
Ended up spending a bit extra but I'll soon be the proud owner of a Samsung UE65JS8500 SUHD TV
I highly recommend anyone having these issues gets in touch with their retailer and fights for a replacement - the only way Sony will stop treating its customers with such contempt to sell us poor quality products is if they suffer financially for it. I only wish I'd stuck to my instincts and bought the Samsung first time round.
Applied the latest updatw last night and so far so good - seems to have improved Youview responsiveness and is also generally a little quicker at responding to things like volume button.
No problems with lipsync but I've never been able to set anything other than PCM output on my set - it's greyed out.
Too early to say if it's made the set more or less stable but stability was pretty good until now. I only got the set a couple of weeks ago and immediately installed the update available at that time and thus missed a lot of the early bugginess and instability.
