to the best of my knowledge, you have to have a drive dedicated to the Tv. The files on it are encrypted to prevent export to other sets / devices. When you attach the drive and register it with the Tv it will format the whole drive and not just a partition. I had to use my PC to reformat the whole drive before it was recognised and registered.
your interpretation of the press release is how I see it. I don't recall seeing pause rewind in the online manual.
Had a proper explore and test in John Lewis today.
The assistant was super helpful, very knowledgeable and quite candid. His advice reinforced everything from reading this message thread. I've no doubt, the sony andoird sets have been causing them more issues tand headaches than making a sale on them was worth. I could get lucky and get a set that works fine, I haven't got the stomach for the fight, cba to think about continuous resets and updates non stop. However, the sticking point for me isn't that the Sony system has niggles/problems but how the company has dealt with the issues over what seems to be an inexcusably lengthy period.
I'm likely going to buy a Samsung UE55JS8000. I took my own content in, had a good play & was particularly interested to see how different sets handled upscaling & motion with some football. The Sony and Samsung stood above the LG and Panasonic sets in my subjective non scientific opinion.
Android TV does appeal but I'll more than likely just use a FireTV 4k box to sideload apps that I would have looked forwards to integrating with the Sony panel.
Sony you've dropped the ball. I'm 'out' before I even got 'in'!
Thanks everyone for sharing your experiences. Wishing you all the very best of luck!!!
Hi you will lose all apps if you do a factory reset.
The other is a software bug!.If you have an audio system you will find that the audio will be from the last selected source and the picture would be from the previous one!!
paulryan37
Try pressing the Home button on the remote and scroll down to Settings>External Inputs>Bravia Sync Settings>Bravia Sync Control (set this to ON)>Auto Input Change (set this to ON) then TV on the remote to exit and try changing sources or switching the DVD recorder ON from standby.
Hope it helps
Has anyone noticed that lip sync is way out of wack with latest update. Before I had to set 80ms delay on my Sony 1050 AV receiver. Now nothing seems to work, I can set it to HDMI auto and it is nearly there but Sky, YouTube and Netflix are still screwed up.
It was perfect before latest update?
@rsebre wrote:
I'd love to be able to control my home, such as light ect by just talking to my tv.
This is doable now. I have Philips Hue lights controlled by Tasker via Google Now voice commands from my phone. And probably talking to your phone is eaier than shouting at your TV?
This refers- http://forum.xda-developers.com/android/general/tasker-project-to-control-philips-hue-t3071719
paulryan37
Hope it helps
Sorry thanks for trying to help but already set up like you said
Lip sync spot on sound through a Sony HT-XT100 soundstage.
TV seems to be far more responsive after todays firmware update fingers crossed it is now fit for purpose. Youview faster, all menus work as soon as the set is switched on.
Not interested in HDD recording or picture in picture etc so not bothered if these work perfect or not.
Still have the Bluetooth issues with new firmwear
Bluetooth randomly switches off and wont let me switch on without resetting it
which means the touch controller wont work
what a farce this is. A top range TV that does not do as it says
