@frogger38 cheers for trying, my tv is 2015 KDL 55W755C but I've got Youview disabled as I'm using the USB recording.
Bug with new firmware
Google Play Music was running on my KDL-43W756C this morning with sound out via optical cable to my LG Soundbar. I switched off the TV but not the soundbar. All music playback stopped as expected.
With the soundbar still on, unwanted music playback resumed, but restarting the playlist, some minutes later. The indicator light on the TV was off.
I tried it all again and the bug is repeatable.
re KD43x 8305 usb hdd recording,I have connected a seagste 240 gb portable hdd with recording and playback pause ,play ff all working fine,
But if I power down with the remote control the hdd is still powered by usb 3 with drive spinning,I was hoping to leave the drive connected permanently.
Is there any way to stop drive spinning or do I need to power down when TV is not in use,or will a ssd drive be a better option.
Any advise would be appreciated
regards
I have noticed this too, looks like they want to wear out your hardrive quickly so you buy Sonys own brand... looks like there is a bug in this.
Anyone else have this issue?
I have noticed this too, I connected our 500gb Samsung drive a few months ago and noticed that the drive was spinning up/ winding down every so often even without the tv turned on. I am concerned about the longevity of our drive! Couple that with the lack of pvr type function i.e pause and rewind tv, the fact that I cannot partition the drive to have one side recording and one side storage and the long list of other niggles and faults with this tv makes for a VERY POOR purchase! Did I mention that we have had our tv replaced with new 5 times, yes five times!
I could also add as it's hdd related... Since the latest firmware update there is a bug where ethernet is randomly not recognised with the tv saying it's not connected but it is and our network is fine, it did glitch a couple of times during ownership of all the tv's we've had of recent, anyway the way that this would be fixed would be to hold down the power button and soft reboot the system, that problem is now cured until the next time. Now, if I soft reboot the system the tv fails to restart and just hangs on the Sony logo screen, the only way to get it going is to remove the hard drive. Once removed it starts up, plug the drive back in and it works as it should?
Pile of junk! Sony KDL43W755C
Hello All
There has been quite a few comments over a period of time in regards to your concerns that Sony would cut support of their 2015 TV range once the 2016 TVs get released. I hope to put your mind at ease over this issue.
There are three particular categories:
Hopefully this helps ease some of your concerns
Not really!
Yes there is an issue since previous firmware which is not solved with latest, at 5GHz connections.
Seems like transmition or receiver sensitivity at 5 GHz is set by drivers in firmware at Low Setting. There is no problem at 2.4GHz.
I usually resolve by soft reboot or placing a wireless repeater closer to TV set.
KD-55X8508C
New feature request
Generally very happy with the new build, now it has originally promised features and is quite responsive.
Now I have disabled YouView so I can use HDD rec, there is a new? Issue, which I though was resolved...
MINOR issue
Pass my thanks to Sony, I am happy that I waited for the updates and not exchanged the set for an alternative a suggested by my retailer. I would like to be able to use Youview without disabling HDD feature though.
