55XD9305 Headphone Use
bikeeandy
Member
As the headphone socket is behind a panel, I'd like to be able to leave a cable plugged in at all times, plugging in the headphones when I actually want to use them. By default, if anything's plugged in the headphone socket, it cuts out the TV speaker.
I was able to use, Home, Settings, Sound and then the 'Headphone Speaker Link' option to allow sound from both speakers and headphones. However, the only sound you got from the headphones was the background noise/music, as opposed to any dialogue.
Any ideas?
2 REPLIES 2
Anonymous
Not applicable
Hi there
Sorry that you have not had a response sooner to your question - when I have used headphone speaker link (although not for a while) - I have managed to get the exact same audio that I get from the TV speakers.  Are you still having a problem with this or have you managed to resolve it?
bikeeandy
Member
Gave up trying. No acceptable solution found. Still want to be able to do it.
