Hi, I have a Sony Android TV (KD-49XH8196) connected to a Sonos Beam sound bar, a Virgin V6 box & a Sony DVD player. I have an audio sync issue with all of these that wasn't there until i installed the Sonos Beam sound bar. I need to advance or speed up the Audio or delay the video somehow. On the Sonos app you can only delay the sound not speed it up so that's not an option. I have now connected the beam to TV with an optical cable rather than HDMI. I have adjusted the audio setting in the V6 box from Dolby Digital to Dolby to PCM. I've played with several different settings on the TV but still got the issue. It's only out by a small amount but i need to sort it. Please help me!!
I think your best bet is to continue with Sonos https://en.community.sonos.com/home-theater-228993/audio-sync-issue-6847651
Have you turned audio sync off in your TV settings?
It sorted out my audio sync issues with an AV Receiver.
Thanks for the replies Chaps, much appreciated. Unfortunately i don't seem to have an audio sync setting on my particular Sony android TV? Also Sonos don't seem to be able to help me any further as you are only able to delay audio on their app & i need to go the other way which isn't possible. I seem to have gone as far as i can with it given the products that i currently have. I could change the setting on the TV to PCM but this greatly compromises sound quality so what's the point in having a soundbar. I saw someone mention a HDMI switch with optical output? does anyone think that might help?
Do not think adding an extra device will help. For A/V sync setting you should have this menu
https://www.sony-asia.com/microsite/support/interactive/pie/index.html#tv_emu_a_p_set_av_sync
Hi & thanks for the detailed option. I've followed your instruction but there isn't an AV sync option on my android TV?
Is it on Android Pie? May you post a picture of the same menu on your TV?
No problem, please excuse my ignorance but how do i attach the photo's i have taken on here? Thanks
Just use the highlighted button
