migibbe
New
Bravia kd55x8505b
Internet browser stops working and the message "internal erorr" appears . Any help appreciated
3 REPLIES 3
Mick_D
Hi there, welcome to the Sony Community :slight_smile:
This issue is often resolved by one of the following things:
  1. Ensure that you have the latest firmware installed
  2. Perform a factory reset of the TV
Try that and see if it works.
Mick
migibbe
New
Thanks for the reply , tried firmware upgrade and reset, no joy, suspect a contractural problem
Sean_Mc
HI there,
If you've tried the following suggestions and the issue has not been resolved, it might be best to get in touch with the support team for further help here.
Cheers,
Sean Mc
