Hi,
I have a problem with my KDL-55W755c
If it is left for a period, say 6 hours the LED will shine but the TV is not on. I can turn the TV on with the remote but then it doesn't respond to the remote, the LED doesn't change and I have to turn the power off to the TV after theis it works fine. I can't power it down with the remote or the power button at the back of the TV, it has to be completely switched off at the socket.
I have tried a reset and hard reset of all settings and still seems to do it. I did install a couple of apps before this all started happening. It doesn't always do this. I have uninstalled the apps and also purged the cache.
Any suggestions?
I totally agree with you about it should have been fixed by now. My issue has returned again and it's hit or miss whether it will start without freezing.
I appreciate there is a work around with the app and factory resetting but this is now unacceptable. I bought a TV and a remote control and the remote does not operate the TV most of the time on startup. I keep checking whether there has been a firmware update but am losing faith now.
I am considering returning the TV to the retailer as being unfit for purpose.
When are 2015 models getting updated to marshmallow android?
No response from the remote. It's a very random problem and I cannot seem to replicte it. It just does it when it wants.
I would have thought SONY would have this issue licked by now. I really don't want to have to keep resetting it, ive already lost my perfect pictures settings.
I am using wireless but cannot use ethernet due to the TVs location.
It seems strange that the problem can be allieviated using the app
I have resigned and now I'm waiting some minute until the LED light up under the bottom of the TV after switching on the main voltage.
Then I directly press the start button on remote control !
It always works !
Perhaps an update of the softwareit will occure some day in the future - you'll never know!
/ Kalle in Sweden
