Делитесь своим опытом!
I have a KD-49x8305C, automatic update is on and firmware is upto date.
When watching catchup TV on any of the channels with adverts, the program restarts from the begining at the end of the advert section. This has happened since the latest Android firmware update was installed.
Hi there
Please see this thread:
The problem is confirmed on All4 only. If you are having problems with other catchup apps, try a factory reset of the TV.
Yes, ALL4 only.
