- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-65X8509C bought within the last week
I have the TV's IR Blaster setup to control a BSkyB Sky+HD box, and most controls work great. However, the UP/DOWN/LEFT/RIGHT navigation buttons work, but always sends 3 occurrences of UP, DOWN, LEFT, or RIGHT instead of just one occurrence.
So, for example, when navigating the Sky+HD box list of recordings, pressing down skips down 3 recordings, making it impossible to select the recordings in-between.
Is there some way to update the IR blaster database to correctly only send 1 occurrence of LEFT, RIGHT, UP, or DOWN when that button is pressed? Or is there any other solution to this problem, that will make the UP/DOWN/LEFT/RIGHT buttons behave correctly?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for the reply, unfortunately I still have the problem with the version of firnware PKG3.315.0102EUA that you refer to, On checking for updates I am told that the TV is up to date!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To All
If anyone else that normally has this problem, can you please confirm if the latest FW has fixed this issue or not? As from my information, this should have been resolved....
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
CUCO
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Still not working
how difficult can it be!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have just checked on the TV - no updates are available (the TV is up to date) and the TV still at 3.315.
Has there been any information from Sony on this issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
No new info im afraid. Hopefully in the next FW update...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have just applied update ...3.395 to the Sony 55x9005cdu TV and the problem with controlling the Sky box is till present.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I also still had this problem after it was supposed to have been fixed in the March update. A factory reset finally resolved the issue.
