profile.country.SE.title
timpannn
New
no rakuten.tv
I bought the A80J and i cant find the Rakuten.tv app. Please consider adding it
5 REPLIES 5
rooobb
It should be already there, contact them if you cannot find itIt should be already there, contact them if you cannot find it
timpannn
New
It's not available for my country (sweden) I hope they add it in the future since j use it on my other tvs
rooobb
Indee, in Sverige is not listed, but I still think you should ask them why, it should be their interest to have more platform enabled. It is a commercial issue in any case, since technically the app is supported.
As a workaround, you should be able to cast movies from a smartphone to the TV.
Anonymous
Not applicable
Hi Timpann,
Did you try to install it from play store?
timpannn
New
Yes
