Does anyone know what type of power cable the A95L comes wtih in the UK please, i.e. is it IEC C13, IEC C17 etc?
Hi @Snerkler
I'm sorry that I cannot help you with a A95L, but here is an image of the A95K. Could be completely different of course.
Thanks for this @LightFoot . I would assume that the A95k and A95L use the same power cable, is yours a UK TV?
Thanks.
Just to update this thread, the power cable on teh A95L in the UK is fixed and cannot be replaced. Bad design choice in my opinion, had to get an electrician out to put a socket directly behind the wall as you can't feed the cable down the wall recess.
If the cable is otherwise long enough to reach an existing socket, one solution is to cut the plug off, feed the cable down the wall recess, and then put a new three-pin plug on at the bottom.
Too late for you perhaps, but may help someone in the future.
Hi @Snerkler, the A95L's power cable is fixed and can only be removed by a service centre. Otherwise it may cause physical damage to the TV. Would you like to replace the power cable which came with your TV set?
