Hi there
I can only suggest a power reboot at this stage - Press and hold the power button on the remote control for 6 seconds or so and the TV will reboot itself.
Hi,
I had same problem. But, change batteries and now is ok. Is it possible that new Sony batteries full drain in one mounth? If disable bluetooth help long life batteries?
