SKYQ 2TB HDR-UHD BOX TO PHILIPS HUE SYNC TO SONY TV , only 8bit, will not allow 10bit
SOLVED
ROBJARVIS
Explorer
My SkyQ UHD-HDR box connects to a Philips hue sync box (light strips on the back of TV that changes colours to whatevers displayed on the screen), from that philips hue sync box goes to the TV's HDMI port, now when i go to sky settings to set UHD 10bit it only alows 8 bit, but when i connect directly from skyq box to the tv it allows 10bit. :-? thinking maybe the philips sync box doesn't allow 10 bit to pass through???
SO... i connected the skyq box directly to the TV, went to sky settings, and set UHD to 10bit. unplugged the hdmi and routed it through the philips hue sync box, from that to the TV... it still says 10 bit in the settings.
But if i try to do those settings while connected to the sync box it only allows uhd 8 bit.
Summery:
connect skyq box direct to tv get UHD 10 bit in settings
connect skyq box via philips hue sync box only allows UHD 8 bit in settings
so connect directly skyq box to tv , go to sky settings, set to uhd 10 bit and allows it, unplug hdr cable and route via philips hue sync box then to tv, go to settings and still says 10bit.. but if i come out of settings and try to set 10 bit again, it only allows 8 bit.
TV: SONY KD-55XD9305
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xd9305/speci...
PHILIPS HUE SYNC BOX
https://www.philips-hue.com/en-us/p/hue-play-hdmi-sync-box-/046677555221#features
Hope this makes sense.
Rob.
1 ACCEPTED SOLUTION
Accepted Solutions
ROBJARVIS
Explorer
So, I found out only ports number 2 and 4 are "enhanced"
ports 1 and 3 don't allow full hdr
the philips hue box only supports 8bit  in ports 2 and 4. but not 10bit
5 REPLIES 5
rooobb
This thread may help https://www.reddit.com/r/Hue/comments/hn3tlw/sync_box_do_ports_2_and_4_have_more_hdmi/
In any case the TV has nothing to do with you may want to seek for Philips or sky support
ROBJARVIS
Explorer
Thanks messaged, both Sky and Philips
Joe_Dohn
Specialist
@ROBJARVIS Have you had a reply from them yet?
ROBJARVIS
Explorer
Joe_Dohn
Specialist
@ROBJARVIS
Thanks a lot for taking the time to share the update, much appreciated!
This will help others with the same question in the future ^^
- JD
