Sony Bravia KD-55X8505C issue
apestrife
Novo
Bought a Sony Bravia 55x8505c in Sweden the other day. Updated it yesterday.
And now it flickers a bit on the right of the screen. Upper and lower right.
I filmed it at it's worst. https://www.youtube.com/watch?v=2nP-06UEP_A
I turned it off for a while, and then it seemed OK, but there are still a small flicker now and then (minutes between). Quite annoying.
It's like a "box" of flicker. Thought it was a buggy pop up window at first, but looks like "white noise"-ish.
Any ideas what to do?
Please help.
3 RESPOSTAS 3
Anonymous
Não aplicável
Hi there
Does this occur all the time, on any input source?
As you have just updated the TV, can you do a factory reset?  I have seen a factory reset cure many weird issues, so worth a try.
apestrife
Novo
hi,
thanks for getting back to me on this.
Nothing was connected. Happens both when I'm watching something through a HDMI port, on a usb memory stick as well as the youtube application.
I've tried doing a factory reset as well rebooting (by holding down the power button), but none of it helped.
While the flicker has become less rampant than in the video I posted, it's still happening. When I'm in the main menu it happen's rarely but when I'm watching a video it every other minute.
Perhaps it's a hardware issue?
Anonymous
Não aplicável
Hi there
Unfortunately the only thing left to assume is Hardware issue as you say.  Time to contact the retailer and ser if you can exchange it.
