Sony KDL32WD756BU TV
SOLVED
LawrenceBruce
New
There are pre installed apps on the Home Screen; but no facility to down load additional apps. Can anyone help?
1 ACCEPTED SOLUTION
Accepted Solutions
jumpsuit
Hi @LawrenceBruce :slight_smile:
Unfortunately you can't install apps to that TV,
you can only use the preinstalled ones.
1 REPLY 1
jumpsuit
