I have heard of it x90j has juddering in gaming and green blemishes on Dolby vision is this going to be fixed. I am looking to buy but not is these dont get fixed.. 😊
Probably your source is this one, and got confirmed fixed after the firmware update
That's good thanks only other thing is, The auto audio calibration on the TV, does it work if you have a soundbar connected. 😊
How can it work? It is something the amplifier of the soundbar should take care of
The TV senses what's in the room, and calibrates the audio.. That what it says on the X90J video..... I am Asking if this works from TV to SoundBar... no major issue i have the sony XF9000 Soundbar, with my sony 43-xg8396 TV.. But if i get the X90j or x95j was wondering if the option of the TV (auto audio configuration) works with SoundBar. That all..
