Sony Xperia C always run out on internal memory and it is preventing APPs installation even onto Micro SD card. Any other work around for this phone?
i have the same problem why don`t they make them merged please any one got solutions reply
Hi All,
After many mail thread i dont think so ,a porper response from sony regarding space issue.
hence i tried a workaround to overcome this issue. it worked great
My sister had android phone where she installed (app sender) app. I send her installed app via app sender and recived the same via bluetooth in sony xperia C and installed the app.
I had internal memory of lesser than 100mb . the app is getting installed in SD card. i hope this workaround would help .
i have learnt a lesson that i should not trust sony from this product.
my mobile memory shown when i try two download to download new apps& updates of apps my device has not support it shows devoice memory is insufficent but there devoice memory is some space is there
As long as you have less than 50 or 60MB you will continue to get the same message
I have 8MB memory card in my device. 6MB is free now. But when I try to download apps it show no enough memory.
That's not enough memory
Hi all,
Even though there is 100 MB of space on my xperia c phone, am not able to install any apps..everytime i try to install an app, i get this 'Insufficent space in device', the device android version is 4.2.2 (16.0.B.2.16 build).
This happening after the above buld was updated. Is there a solution to reslove this issue, I cannot use my phone this way.....
Not sure it will fix your predicament however you could try using Clean master from the Play store to clean out the cache and any other old files - This may fix your issue but I can't be sure
