I have a cyber shop DSC-HX50 camera which I don’t use anymore. Should I remove the SanDisk SDHC Card from the camera before I give it away? Or are there any other precautions I should take apart from deleting all photographs ?
Hi HeidiP,
welcome to the Sony User Community Forum..
Yes you should remove the SD card or at least format the SD card before giving your HX50 away..
Also you may want to take a look at the following Sony guide on;-
Hi HeidiP,
Thank you so much for your advice and for the link.
BW HeidiP
You are welcome HeidiP..🙂
