call blocking
SOLVED
ca8erpillar
Visitor
call blocking
in call block menu there are options for blocking all outgoing calls or all incoming calls. how to block any specific individual number?
1 ACCEPTED SOLUTION
Accepted Solutions
Rickard
Master
To block a specific number from calling you, save the number as a contact and while you create/edit that contact you should have an option to always send it to voicemail under [menu].
4 REPLIES 4
Rickard
Master
profile.country.RO.title
_alexdon_
Other than the above,you can download apps from google play.
alexdon
Jake-SonyXperia
Champion
Hi ca8erpillar,
I have heard that Calls Blacklist is a good app to try. however you use these apps at your own risk.
I hope this helps.
ca8erpillar
Visitor
thank you! Slightly_smiling_Face
