annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
ClockWorkMod on locked bootloader
RÉSOLU
iGLIDE
Visiteur
Hello
Is there any ways to install clockworkmod on sony xperia e (c1504) with locked bootloader?
1 SOLUTION APPROUVÉE
Solutions approuvées
Thommo
No - This is only possible on a unlocked Bootloader
9 RÉPONSES 9
Thommo
iGLIDE
Visiteur
But xda forum says that it is possible
Thommo
where would that be on XDA as I've checked and see that it says it must be unlocked
Vengence
Contributeur
If your scared about unlocking bootloader you shouldn't be even talking about Cwm
Cwm needs kernel replacement which needs unlocked bootloader
And also what are you planning to do with Cwm on locked bootloader..... Pretty much everything cwm needs unlocked bootloader
iGLIDE
Visiteur
I'm not scared about unlocking bootloader. My phone says that I'm not allowed to unlock bootloader. I want to install cyanogenmod to boost my phone. There are many ways to install cwm on locked bootloader but not exactly for my phone. For example this http://forum.xda-developers.com/showthread.php?t=2187363
Thommo
So you have read that you can for other models but not for your Xperia E - My Z1 has CWM with a locked bootloader
If interested this thread has a list with links to most thing Xperia E and the nature of your topic
iGLIDE
Visiteur
Thanks bro I have also one question. Does sony xperia e support otg?
Thommo
I'll go out on a limb here and say yes purely based on that my Xperia Z1, S and Tipo do the latter been a low end entry level phone from 2012 so I would assume the new phones will
Vengence
Contributeur
Not possible on a locked bootloader... Sorry
There are some ways to force unlock but sim may not work after rom install
Sent through my xperia E with Cyanogen mod 10
