Headphones for E3
SOLVED
syorks
Visitor
Headphones for E3
So, the E3 doesn't come with any headphones. I have the headphones that came with my Xperia Ray, but they only worked once, now the phone plays the music whether the headphones are plugged in or not, and nothing comes out of the headphones.
I understand that Headsets aren't compatable between the two phones, is there a reason that these headphones aren't compatable ? I have found a very cheap old pair of headphones and they work ok.
If it is a compatability problem, what spec do I need to buy for the Xperia E3. Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
syorks
Visitor
If I am buying earphones that will only "theoretically work", I'd buy a much cheaper set. Thanks anyway. Found a great Nokia set that works anyway.
4 REPLIES 4
profile.country.RO.title
_alexdon_
Yes,older Xperias had OMTP output.The new ones have CTIA.Check the sony website:
http://www.sonymobile.com/global-en/products/accessories/
alexdon
syorks
Visitor
Thank you for replying. When I am looking around at headphones, I have yet to see any mention of OMTP or CTIA. Take, for instance, these Sony headphones that give the spec as -
Sony MH-EX300AP Make phone calls and listen to Music Sensitivity (db): 105dB/mW Magnet: Neodymium (440kJ/m3) for outstanding bass performance in a small driver Plug: L shaped stereo mini plug Impedance: 16 ohms at 1kHz
Am I right in thiniking that any headphones that don't include a mic are ok ?
Thank you.
_alexdon_
You could buy any of the sony headsets or headphones,theoretically they should work.
alexdon
syorks
Visitor
