low phone memory for no reason
SOLVED
Vengence
Contributor
Screenshot_2013-10-06-17-05-09.pngScreenshot_2013-10-06-17-05-35.pngScreenshot_2013-10-06-17-05-50.pngScreenshot_2013-10-06-17-06-22.png
1 ACCEPTED SOLUTION
Accepted Solutions
Vengence
Contributor
Problem fixed itself..
10 REPLIES 10
Vengence
Contributor
all i have installed are 2 games and 4-5 other apps and all are moved to sd [those which can be moved]
Vengence
Contributor
Can't even install apps now .....removed most apps still......
AkshayVn
Visitor
The phone takes 80 mb for the messaging services and all and you have used most of it and only 70 mb left so it is showing like that
its not a problem just give 80 mb to the phone and remove google app updates then it will be good
bhuvaneshdesai
Visitor
it is good that you have es file explorer
just open it and run the sd card analyst
the dcim folder contains 2.big files just delete them you will free up around 500-600 free memory.
make sure you delete them regularly
bhuvaneshdesai
Visitor
and also don't update the apps that you are not using.
also uninstall chrome updates as there is nothing new in it
bhuvaneshdesai
Visitor
did you got those toggles in notification bar after update
Vengence
Contributor
Power toggles app
profile.country.RO.title
_alexdon_
How about if you clear data for media storage in settings-apps-all?
alexdon
bhuvaneshdesai
Visitor
clearing data also works but it gets created again when you use that respected app
