PC COMPANION problem
SOLVED
tonyjaimy
Visitor
I'm trying to update my xperia e with pc companion
After download software it's shows "Switch off after 5 seconds connect to computer PRESS AND HOLD VOLUME DOWN KEY"
i did same but my phone not connected
So i can't update my phone software
Please anybody help me
1 ACCEPTED SOLUTION
Accepted Solutions
tonyjaimy
Visitor
Windows 7
I did it several times but. Same error
3 REPLIES 3
profile.country.RO.title
_alexdon_
What windows are you using? Repeat the process several times (connect with volume down).
alexdon
tonyjaimy
Visitor
Windows 7
_alexdon_
Could you try on another computer?
alexdon
