SD Card
SOLVED
mysonyexperia
Visitor
SD Card
Hello.I want to find out how can I format a micro SD card. Notice that I tried to erase everything on it,but it says '''Blank SD Card'' and i can't do anything on it.Please Help me!
1 ACCEPTED SOLUTION
Accepted Solutions
discretion1
Contributor
Format your memory card using your computer, verify that it is readable by copying contents to it and then insert it into the phone.
2 REPLIES 2
mysonyexperia
Visitor
Hello.I want to find out how can I format a micro sd card to introduce it in phone.Notice i have a Sony Xperia E dual and i tried the ''Erase SD card'' option,but still didn't work.It says ''BLANK SD CARD''.Any suggestions,please help me.
discretion1
Contributor
