One question - can this be repaired 😢
Hi @Mullza82 and welcome to the Community
Wow, how did that happen?
What TV model is it?
It's possible it could be repaired however as that looks like physical damage then it
won't be covered under any warranty.
You may have the problem of deciding whether the cost of repair (which will probably be quite expensive depending on the damage) is worth it or not compared to getting another TV.
The best option is to contact Sony Support about this to get a quote.
If its an Android TV Here is the place to start.
