Hello, I sent the form with all required documents about a month ago but I did not receive any info what is going on with it. Is there any way that I can check the status of my cashback claim?
Hi Kiub2005.
There is a helpline telephone number to call:
0845 5048939
Thank you thought that maybe there is some kinda way to check it online or to email them ;]
No, as far as I know there is just the Hotline telephone number.
I believe handling of these cashbacks is outsourced.
Try calling that number and prolly ask if ther's an option for you to check online. You can use that in the future.
I send away my appliation for Sony cashback for £50 on 4th December 2014
Until now I have not received it or any emails says what the delay was.
Kindly look into this matter as soon as possible as i am eagerly awaiting my cash
I tried to contact someone on the number 0845 8048939 and was told this number no longer takes calls
Hi @annbarne0
I have reported your complaint onto Sony as an escalation. Please ensure that you have the correct details in your account profile as someone should hopfully be in contact with you.
Thank you for your help am still awaiting a reply from 21st January about my cash back. I'm not sure how the reply will be sent but would appreciate a speedy reply. Once a g ain thanks( I have been waiting 4 days for response)
