Hi
I have a Sony CMT-SPZ90DB and there is a problem were there is only sound when I use the headphones, no sound out of the speakers !, any idea what the problem could be ?.
cheers
Spike
Assuming that this is a recent issue and that the device has been working fine before, then you might wanna reset it to it's original factory settings to check but if it persists you might need to contact Sony directly to check with them.
Check the troubleshooting section on page 2 on here:
https://www.sony.com/electronics/support/res/manuals/2688/26885781M.pdf
Hi
Fantastic, thank you that has done it, now working fine, could not see any info in the SM for it and I diddn't have to user sheet, I can't beleive I have saved it from the skip.
thank you again so much
cheers
Spike
You're most welcome, glad i was able to help.
Hi again
Just a quicky, give wrong info initially , I mean is dosen't matter now, but my Hi-Fi is Sony HCD-SPZ90dDAB, not sure what the difference is, but the sound out of mine is extraordinary for its size, thanks again for your reply.
cheers
Spike
