- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
November 2017
November 2017
Ct-180 sound bar problems
Hello
My soundbar is playing up. I get a muted sound from the bass unit but NO sounds at all from speaker bar itself. I've tried a system reset with no luck, and the optical cable seems ok (no damage, and red light visible).
Any ideas please
Thank you
1 REPLY 1
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2017
November 2017
Hi there,
The first step in the troubleshooting process is a factory reset.
Once done, check to see if the cables are connected properly and then set it back up again. If this doesn't work, let us know.
Best wishes,
M
