отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
DAV-TZ715
РЕШЕНО
Korabid
Новый
DAV-TZ715
Hi I have one DAV-TZ715 Home Theatre System but is peasing me off because in some days of the month it shut downs automatically. Also after I turn it on after few minutes it shuts down. Some days of the month it doesn't happend. I tried to find where to stop or reset to factory settings but I didn't find any solution yet! I find one but it didn't work on my model.
Please help me.
Best regards
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Anonymous
Неприменимо
Hi there
Sounds like your DAV system has PMS.  None-the-less, you can factory reset it by:
2 ОТВЕТ 2
Anonymous
Неприменимо
Hi there
ojamesodanga
Новый
Cold reset worked. Bravo!
