Desperately need help with bdv-n5200w and Harmony
Staffy2702
Novo
Hi all
Thanks for having me in the group.
I'm literally desperate for help
I have a Sony bdv-n5200w surround sound system with the following.
Sky Q plugged via HDMI to tv with optical cable to DVD player.
In DVD player i have Nintendo Wii and firebox. These are plugged into DVD as HDMI ports on TV are full.
I want to set a simple activity to click 1 button to allow me to change tv to hdmi2 (DVD player menu) then change to DVD HDMI 1 so I can play on the Wii......and another activity to go back to sky.
However Harmony chooses the wrong source no matter how I adjust it.
I've exhausted all I know about Harmony and can't get it to work
Hello please
Paul
1 RESPOSTA 1
cass_n
Hi @Staffy2702 and welcome to the community :slight_smile:
I don’t know much about the capabilities of Harmony, so hopefully another community member might be able to chime in.
In the meantime... the problem might be related to CEC (BRAVIA Sync) control - so you try again without CEC enabled and see if that makes any difference?
Cheers,
C
