Partagez votre expérience!
I have just logged the following message to SONY via their contact-us form - hopefully they may see it over the weekend (:smileygood_luck:
" Please see community Blog - the automatic software update on digital HDD/DVD players made by Sony across the board on Friday, 19th July 2013 has failed.
My RDR-HXD890 does not have any digital channels, EPG or any Digital Signal. My 1st response yesterday was to re-scan, recorder shows all available channels are picked up, but no signal throughput? My 2nd response was to try & update the software downloaded from your website - the recorder gets to DOWNLOAD-5 and gets stuck - none of the switches on either the remote or the HDD will function - only solution was to unplug-wait & re-connect.
This morning the recorder is stuck on update! It appears that ALL your customers are having the same problem. I had 5 programmes scheduled to record from yesterday evening - of course nothing has recorded, as no signal/channels available.
I am sure there are a lot of customers out there who are not technically savvy, they would automatically think their equipment has failed, so go out and replace it - BUT once this episode gets out your reputation will be in tatters! SONY - do something very urgently!"
Has anyone posted this on Twitter? Perhaps Sony will notice that? It seems a news-worthy story (BBC?). I was planning to buy a new recorder today as I assumed mine was the only one. I am sure lots of people will do that.
sending this to Sony
Many thousands of people are having the same problem, I have 2 RDR's,
both failed at the same time last night, a million yo one chance if it
was a single machine fault, rang 4G to see if it was there problem they
said my area not on 4g yet, but as others with Sony equipment had the
problem, to try the Feeview supplier, phoned them and they said we have
no problem with our signals, but have had hundreds and hunreds of calls
from people with Sony equipment, and it seems to be a major Sony fault.
they gave me a number, but as it is saterday no one their till monday,
would have thought an international company as they are, would have a
decent help line.
If Sony do not respond quickly, only alternatives are to flood the Government
and media with complaints eg, media watchdogs, Office of fair trading
(Equipment not fit for purpose)m and local MP's ( but as they are on
holiday!!!!)
hold RECORDER power button for 5 seconds if its stuck in update until it switches off, quickly tap the recorder POWER button until it wakes up and says welcome
menu , easy setup , english language , autoscan , FRANCE for location, and scan for channels
it will freeze on the clock for 2 minutes or so, then may try to scan analogue, so exit out
press and hold power button on recorder and turn off
press again to wake it up
freeview channels should work , menus will work, title list will work , dvd playback will work
but no epg for now so any timer recordings will be manual like on an old vcr
hope that helps
Hi All,
before posting any further comments please read this thread
