ISSUE playing 3d from USB
SOLUCIONADO
wcervant
Novo
I own the Sony 5.1-Ch. 3D / Smart Blu-ray Home Theater System
Model: BDVE3100
When I attempt to play my 3d movie from my USB jump drive, the movie plays in a split screen, but it will not play the screens together. I tried to click 'OPTIONS' --> "3D Menu" but when I get to the 3D Menu the only choice available is "Simulated 3D". "3D Depth Adjustment" and "2D Playback" are both grayed out and unable to access.
What do I need to do to turn on the Sony blu-ray player's 3D feature and watch the movie with the screens joined, not split?
1 SOLUÇÃO ACEITE
Soluções aceites
rooobb
Have you tried to adjust the 3d options on the TV instead of the player? It should work (or at least it does on bdps5100/kdl42W805) letting stream the movie split from bluray to tv and then forcing the TV to get it as a 3d flow
1 RESPOSTA 1
rooobb
