Hi all,
I got a UBP-X800 player today. While the picture and sound quality are great, the 4K picture input is really 'fake' looking. Basically, it looks like one of those cheap American soap operas.
I also have a Sony KD49X8505B TV.
On all my other inputs, on the TV remote, there an option to adjust the motionflow so that I can correct this effect to something that looks more like a normal cinematic movie; however, for this player (and only when using a 4K input) this option no longer appears to be accessible via my remote.
Any ideas how to adjust the motionflow with this player?
Oddly enough if I play a DVD or standard BluRay, the motion is normal and as per the settings I applied for our old player / Sky box etc.
I don't understand why having the player connected to the TV prevents me from accessing the normal menus to allow me to adjust these settings.
Any help would be greatly appreciated as I am starting to lose my rag with it!!
Cheers,
Andy
Gelöst! Gehe zu Lösung.
Hi,
Press the SYNC MENU button on your TV remote control. A window will appear on your TV screen with several options. Select [TV control with the TV remote]/[Device control by TV remote], this toggles the TV remote to either TV operation or device operation. In this case you want TV operation.
Please see this page of your user manual
Regards
Stand down: I finally got the damn thing working!
Turns out you have to set your TV remote to specifically act as the TV remote (who knew?) and then you can do it.
Without that, all settings on your TV remotes are overridden by the player's menu options.
*bangs head on wall*
For the benefit of me, can you give a quick idiots guide on how to do this!
Hi,
Regards
Thank you very much, most helpful.
You are welcome
Regards
