Sony BDP-S490 BluRay Player
Damon91
Hi all,
I'm going to buy the Yamaha YHT-199 home cinema system very soon, Speakers with AV Receiver. I will be needing a BluRay player to go with this system, and I prefer to have one matching brands so either one of Sony or Yamaha is what I'll be buying as a BluRay player.
I've seen the Sony BDP-S490, which looks decent to me. I will mainly be using it for YouTube so it must be able to play the 'HD' videos, and also for playing big 1080p MKV files from an External USB hard drive.
So, does this player (Sony BDP-S490) play all/every MKV you have thrown at it? 1080p MKV in 2D and 3D without any problems such as lag/stutter? Will it play YouTube videos in HD? How about subtitle/chapter compatibility in MKV, does it allow you to skip chapters? Does it play subtitles if you drop it into the folder named as the MKV, must it be muxed into the MKV container?
Lastly, what is the model after this one, if this one isn't any good?
Please advise, appreciate your feedback, thanks in advance.
17 RESPOSTAS 17
Anonymous
Não aplicável
HI there
The BDP-S490 is a 2012 model 3D bluray player and supports the following video files:
Currently it is retailing on Amazon for £113.99
Opinion:
Its my opinion that you might be better off on one of this years model such as the BDP-S5200 which is a Smart 3D Bluray player with Wifi which is retailing for £106.33 (Amazon).
The BDP-S5200 supports the following video files:
Manual located : HERE
Hope that assists.
Damon91
It helps a lot mate!
Can you list this years models that support 3D? I'll pick the cheapest one, but be nice to know all of this years models.
Anonymous
Não aplicável
Thats alright :slight_smile:
Funnily enough, I created this a little while ago - and never posted it - Comes in handy now;
Damon91
How come I can see other model numbers like BDP-S5100? And difference between that and 5200?
Anonymous
Não aplicável
Not sure which site your on, but the S5100 model is the 2013 model.  In reality, I dont think that there is too many major difference between the two, except that the S5200 supports Screen Mirroring
BDP-S5200
http://www.sony.co.uk/electronics/blu-ray-disc-players/bdp-s5200
BDP-S5100
http://www.sony.co.uk/electronics/blu-ray-disc-players/bdp-s5100
The S5100 is also no longer available via the Online Sony Store.
Anonymous
Não aplicável
The BDP-S5100 is a 2013 model.  I dont think there is much difference between that and the S5200 model except for Screen Mirroring.
Im not sure which site your on, but:
BDP-S5200:
BDP-S5100
However the BDP-S5100 is no longer available on the Online Sony Store.
Damon91
Anyway let me know the differences between the 5100/5200 also I don't need Wi-Fi so I might go for the 4100/4200 instead.
Are there any big significant differences between the two such as dual core playback ect..?
Anonymous
Não aplicável
Hi
Im trying - ive posted twice, and the posts disappeared into never-never land.
TESTING
Anonymous
Não aplicável
There is not too much difference between the S5100 and the S5200 models.  The S5100 is the 2013 model (which is no longer available via the Online Sony Store).  The major difference is that the S5200 supports Screen Mirroring.
If you do not require Wifi, the S4200 would be just as good (which also doesnt support Screen Mirroring either, due to the lack of Wifi).
Hope this helps
BDP-S5200
BDP-S5100
BDP-S4200
http://www.sony.co.uk/electronics/blu-ray-disc-players/bdp-s4200
Hope this helps
