This afternoon I installed my new SVR-HDT500 and unfortunately
when it is switched on nothing happens other than It displays a "Hard Disk
Recorder" message in the middle of the TV screen.
None of the buttons on the remote control do
anything to the SVR-HDT500, It’s not a flat battery in the remote control as I changed
the batteries. I have unplugged the
machine several times but when switched back on the fault persisted. I have tried using the reset button under the
flap on the front but no success there either.
Any ideas?
Gary
Gary,
I have exactly the same problem but am not full of confidence of a fix as I see no one provided any thoughts on resolution. Did you manage to resolve?????
Chris
