SVR -HDT500
SOLUCIONADO
profile.country.en_GB.title
ronliggins
Visitante
SVR -HDT500
svr500 it turns on registers hardisk recorder  then nothing cant get anything on the remote the blue light flashing thats it help
1 SOLUÇÃO ACEITE
Soluções aceites
Anonymous
Não aplicável
Hi there
When you get a constant flashing light on the SVR-HDT500, what you need to do is press the reset switch and keep it held in for about 5 seconds, the light will slow down. Then switch it back on as normal. This switch is located at the front, under the USB flap. You do need a pen to press it in though.
Hope that helps
1 RESPOSTA 1
Anonymous
Não aplicável
Hi there
Hope that helps
