Battery Issue
SOLUCIONADO
santosh9
Visitante
Battery Issue
after replacement my xperia m i feeling again said bcoz its battery drain soon even just listening music and little watsapp.
sony say its 36hr music playback but i dont think so bcoz withing 30min its battery drain upto 20%.( just music without touch any app)
look withing 38 min its drain upto 59% without useing music just 3-4 time watssapp. Smirking_Face
and also i found new small fault its seen in screen shot.. network look full range its reliance sim.. and after lock screen its show insert sim.
and the camera also its not good its burnig in flash and noisey and pixelet the image with high yellow contrass.
17 RESPOSTAS 17
santosh9
Visitante
Ok you mean my screen is consuming more battery ... then i wil try .. and thnx for your feedback and help...
santosh9
Visitante
and one more thing... what is insert sim problem here are image..
https://app.box.com/s/lm74h6ragk9ce9dljcgb
Uliwooly
That seems odd, do you have the Xperia M or M Dual? if the later, do you have 2 SIM cards?
santosh9
Visitante
I am useing Xperia M single sim..
Marcas (1)
Uliwooly
It could be a bug, you could repair your phone with SUS or PCC
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
santosh9
Visitante
ok thanks for help ...:smileyhappy:
Uliwooly
Anytime
santosh9
Visitante
thaks uliwooly ... now its solve.. thnks again...
