- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I left my phone to sleep. i remember it was 49%. when i woke up, i checked the battery. It had depleted to about 41% ! I only left it sleep for about 7hours and it depleted about 7%. is it normal ?
i already turn off all the things like WiFi, Bluetooth, Internet, and force stop the needless application running,
when i checked the what has consumed the battery it says :
Display 60% for 2h 46m 53s
Cell Standby 17% for 1day 1h 18m 47s
Phone Idle 15% for 22h 32m 0s
Android System 2%
com.sonyericsson.home 3%
there !
thanks for your opinion
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
as uliwooly said..it is normal..even my arc 's battery's the same..
i know its odd but we cant do anything.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
this is your first smartphone isn't? yes it is normal, in fact only 7% is really good, battery on a smartphone last between 8-12hrs a day
you can improve battery life by
turn off wifi, bluetooth, gps and lower brightness
if you don't use 3G/Internet you can turn off your data
all that will improve your battery life
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you can use Quick Settings app
https://market.android.com/details?id=com.bwx.bequick&feature=search_result
or
this great widget
Power Control
https://market.android.com/details?id=at.abraxas.powerwidget.free&feature=search_result
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
uhm yes , this is my very first smartphone, and I amazed of how the battery works!
what do you mean by 7 % ?
what i want to ask is : is it normal for the phone idle? it consumes about 1% for about 1hour idle.
is it okay for me to left my phone charged while i was sleeping?
thanks b4
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you lost 7% charge over night, so that's not bad. that's what I meant
you can leave your phone charging overnight, once your phone reaches 100% it will stop charging your phone, once it reach 95% or so it will recharge your phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
so that is what u meant. 7% for standby of 7hours even WITHOUT TURNING THE BLUETOOTH/WIFI/MOBILE DATA ON ? just want to be sure that 1 idle hours without doing anything needs 1% of battery
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
well yes...
u can install this..
https://market.android.com/details?id=com.latedroid.juiceplotter&feature=search_result
and it'll give better view on ur battery;s performance..
just check it out..
if i find any thing abnormal i refer to this app and it tells at what time the battery depleted the most
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you can also check this video (it's for the X10 but the same is true to most if not all smartphones android/ios)
