Hdmi 2.1 VRR sony oled xr-55a83j
profile.country.RO.title
Marius_Rus
Hi all.
I have recently encountered a problem while trying to connect to hdmi 4 in order to display 4k 120HZ from my laptop using the dedicated card nvidia rtx 3070 ti .The image would flicker for a second or two,but won't stay on.I mention that previous to this it worked just fine on the PS5.Now it does the same on the PS5,while setting HDMI signal output to Enhanced VRR the image flickers and stays on for a couple of seconds .If I select enhanced dolby vision it works .
Is there any solution to this problem or should I contact the repair service for the TV.I also mention that HDMI 3 works fine with the same cable.
0 RESPOSTAS 0
