Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
August 2010
August 2010
i was trying to reply to my friend in chinese but was not able to change to chinese input. How do I do it?
Solved! Go to Solution.
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2010
August 2010
Try long pressing in the input box and you should then get a popup that gives you the input method option, select that and select chinese keyboard (X10 biggun)
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2010
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2010
August 2010
Hi Suze,
Thanks. U are a great help...
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2010
August 2010
She is indeed.
You can also use the Chinese handwriter input. It is less taxing on my big fingers, alays tying so har to land on ONE key.....
