I have downloaded the update,updated the play app and when i launch the game it says"sorry having trouble playing this video"?? Anyonbe else with this problem.Also I cannot remove it and try a new download of it.Help if possible? Thanks
Yes, I think you would have to raise this with Gameloft because it seems to be some other problem with the game.
you could repair your phone with Update Service and/or uninstall the app and reinstall it
when u say unistall then reinstall,you r talking about the play app or the game? I didnt think u could uninstall the game?
you could uninstall apps and games but you have to root and then install Titanium backup, but repairing your phone with Update Service should solve this and other issues
If I use update service i should back up everything 1st like u said in the thread? Correct?
I have update service and done the update,it said that my phone doesnt need an update so I will check it now....crossing fingers!!!
yeah first backup everything
it will say that you don't need one, click on install it anyway
no where to click that?
that's odd, on Update Service once you connected your phone on Safe Mode it will say you have the latest firmware and at the bottom right corner it should say Install
