Hi there
First thing to do is ensure that you have the latest firmware installed
Secondly, on the TV, you can turn OFF scene select by setting it as "General". See instructions:
http://pdf.crse.com/manuals/13MW802111/EN/c_aadjust_scene.html
Also try setting "Picture Mode" to Standard as well:
http://pdf.crse.com/manuals/13MW802111/EN/c_picscrn_picmode.html
Ensure that you are doing the picture settings where it says "Target Inputs" set this to "Common" and set Picture mode to Standard etc.
Hi there
I have no other ideas for you im afraid. Unless another forum member has any other ideas, the only thing I can advise is to contact Sony Support directly.
