I want to connect a Android (we are using Android smarthones) tablet to TV KDL-46EX710. Is that possible? What extra equipment do I need?
Today we don´t have a tablet, but that can be bought. And also some extra equipment.
I want to have the tablet with me in the chaire, so I prefere wireless.
Solved! Go to Solution.
Hi there
It comes down to - What do you want the Tablet to do (in regards to the TV)
If you want to Stream a few photos/music/video files via DLNA it should work via wifi using the USB Wifi Adaptor (UWA-BR100 adaptor) and a third party andriod program. I dont think your TV supports WIFI Direct.
"DLNA Renderer : Photo (jpeg)/Music(LPCM/MP3)/Video(MPEG2/AVCHD)
DLNA Client : Photo (jpeg)/Music(LPCM/MP3)/Video(MPEG2/AVCHD)"
However, on the other hand, if you want to "surf" the internet and display it on the TV screen - That is not possible wirelessly.
From my (very limited) understanding - You should/might be able to connect an Andriod Tablet via a HDMI cable (and maybe an extra adaptor). Your best bet is Google.
However, as I always say - Do your research fully before purchasing to ensure that you get the right product that suits your needs.
Hope that helps
Cheers.
Hi there
Hope that helps
Cheers.
