got my new tv can anyone recommend the best setting for the perfect picture.its a little dull and want to get it to the best picture it can achieve
Solved! Go to Solution.
Hi there
You may be interested in this.
http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
Just download which one you require and burn to DVD. Last time I looked at this, the download is small, but blows out to a full DVD.
Hope that helps.
Hi there
The problem with this is : Whats best for one person, may not be best for another. As in, different room layout means different viewing angle/lighting etc. Some may have preference to a brighter screen, others might like a more vivid colour.
When I got my new TV (now almost two years ago, gee time flys). It took me about two weeks to figure out what was best for me. I constructed myself a little spreadsheet - wrote down all the base settings and slowly tinkered with it over time until I got it the way I liked.
The AV Forums has a master thread in regards to the W6 model, which you might find handy or give you clues.
http://www.avforums.com/forums/lcd-led-lcd-tvs/1776014-sony-w6-owners-thread.html
Other than that, happy viewing
Cheers.
Very brilliant picture. I love it
I think Cinema Scene is the best but I would like to calibrate the screen using proper software like Calman 5.
Anyone can recommend any basic free calibration software? It doesn't have to be with any fancy hardware sensors
Hi there
Hope that helps.
