sky remote problems with bravia tv
SOLVED
profile.country.en_GB.title
sunderland73
Visitor
Hi all
I am trying to set up a sky hd remote control to use with my sony bravia 40ex403 tv but it wont work the tv.
I've tried the sony 0000 code without any luck i've also tried the search facility using sky interactive but the tv i have is not listed any help please.
Thanx.
Mick:smileyconfused:
1 ACCEPTED SOLUTION
Accepted Solutions
sunderland73
Visitor
Hi Phli.
I tried the code 533 and nothing happend so i tried 0533 and it worked so thanx a lot first class:smileyhappy:
12 REPLIES 12
Pcadjb
Visitor
Hi,
     I had a similar problem wih my TV, but slightly older than yours 0000 code would not work.
The only way I could get it to work was to enter the 3 digit code 533 and press "select" after enter 3rd digit (LED flash twice) then it worked.
This website may help you http://www.satelliteonline.co.uk/sky_remote_codes.htm
Phil.
sunderland73
Visitor
Hi Phli.
profile.country.en_IE.title
brightspark1
Visitor
code 0533 worked for me aswell thanks
miranda.bend
Explorer
Can confirm that code 0533 works for the model ex403 aswell thanks :slight_smile:
fizmansur
New
My Sony 3D smart 42W829BBU is just days old, and I'm very glad I visited this site. The code 0533 worked for my sky hd remote too. Many thanks to who suggested it.
Shet-Rog
New
Got the new Bravia KD55A1 and found that the code 0533 worked,
PauloLondon
Explorer
Thank You! I just bought the new Sony OLED and tried all codes until I found this answer and I can confirm that 533 (or 0533) worked; I knew because the last recommended action is to press standby on the Sky remote and it turned the TV off whereas all other codes failed. I can now control Sky with my Sky remote on Sony!
Rlvtv84
Explorer
Me too! 😇
I can confirm the code 0533 worked for the 43 inch 8505 TV
