Hi Folks,
do you know if there is a way to connect to and playback content in your UV library on any of these TV's? Is there a dedicated application somewhere?
Thanks,
Gary
Solved! Go to Solution.
Hi there
I believe Flixster is the App you are looking for.
More information :
https://ultraviolet.sonypictures.com/info/devices
Hi there
More information :
Good point, UV's having a bit of a slow start unfortunately. Likely it will pick up pace, but its a big eductaional job explaining to people what they can do. I notice recently they have stopped discriminating between SD & HD titles so even if you get a UV code via a DVD, you can still stream & download the HD version.
Checked Flixster mobile app and doesn't seem to be a way of outputting the stream to TV yet. I don't know for sure, but feels like a logical next step that there would be both a native TV application and airplay type functionality for mobile, but likely just down to resolving security issues first.
