Wifi direct missing from applications on KDL40EX723
SOLVED
M77loy
New
I enjoyed the wifi direct facility on my KDL40EX723 but for some reason it has completely disappeared from applications from the home menu.
I've tried factory reset but it's still not there ... Any ideas??
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
This confirms that you do need the UWA-BR100 dongle:
http://www.sony.com.au/support/faq/464906?site=hp_en_TH_i
With further information:
http://www.sony-mea.com/support/faq/403899
5 REPLIES 5
Anonymous
Not applicable
Hi there
Thats totally weird  I am assuming that you have the Wifi Dongle (UWA-BR100) connected?. If so try the following:
  1. Turn TV Off
  2. Unplug the dongle
  3. Turn TV On again and connect the dongle back in (using top USB port)
  4. Also best to ensure that you have the latest firmware updates installed
Hope this assists.
M77loy
New
My understanding is that you don't need the dongle?? The wifi direct is built in ?
M77loy
New
My tv is wired into my router.
Anonymous
Not applicable
Hi there
M77loy
New
Thanks. I replaced my dongle with wire a while ago due to performance issues..... That'll explain why then, Many Thanks!
