Buzzing sound from speakers on new Vaio E-series
SOLVED
profile.country.sv_SE.title
BLYARN
Visitor
Hello!
I recently received my new Sony Vaio SVE1111M1E. Since the beginning I have noticed a strange buzzing noise from the speakers. It sounds like when you turn up your stereo to maximum without playing any music. Its not always there, but sometimes it sounds for some seconds, stops and then it's on again after some more seconds. I know it's from the speakers because it stops when I mute or put some headphones in there. When I put some headphones into the computer the noise is neither in the phones or the speakers.
I think it can have something to do with when the hard drive is working because when I go through different folders on the computer this noise comes on after every click.
This problem was there when I got my computer, and is still there after i reinstalled my own version of Win 7 and downloaded all drivers again.
I have tried to disable the microphone without any luck.
Does someone know anything about this?
Thanks
//BLYARN
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi BLYARN,
Unfortunately even if this problem was present prior to installing your own OS Sony only provide support for the original OS and they will no doubt ask that you return to factory defaults before inspection.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
Contributor
Hi BLYARN,
Does this happen when operation on battery only? If only when the power adaptor is connected then it could be a ground loop problem.
Either way you will need to contact Support but they will almost certainly ask you to return the notebook to factory settings before investigating further.
Rich
BLYARN
Visitor
Hello!
Thanks for the quick answer.
This problem occurs booth with and without the adaptor connected.
Okay, but i hade this problem with booth their original Win 7 Home and it still there after i reinstalled the whole thing with my own Win 7 Enterprise. It was even there before and after i installed the drivers.
//BLYARN
rich912
Contributor
Hi BLYARN,
Rich
BLYARN
Visitor
Hehe, yeah, and that sucks :dizzy: i've just made the computer ready for my studies but i don't want that disturbing noise there for all future. I think i'll call them tomorrow.
//BLYARN
rich912
Contributor
Good luck and please let us know the result of your call.
Rich
