been trying to enable the 3D function of my vaio vpcl22z1e/b via an acer k330 3d ready projector,i know the resolution required 1024x768,the refresh rate 120hz, can enable the 3d function on the projector, but can't change the hdmi resolution on the pc from ( 720)2d or ( 1080) 2d to 720 or 1080 3d.......... i can only connect the pc to the projector via hdmi ( am thinking of buying an adapter hdmi to vga to see if this helps)......however i beginning to think its impossible to make this 3d work at all....any ideas ?
